I'm about 1/4 the way through tiling the kitchen dinner floor (30m2) and the old corded drill I'm using with a paddle mixer on has nearly burnt out.
I need to use something to mix the rest of the tile adhesive with(4 or 5x20kg bags) and then the grout and then use very occasionally for the odd bag of plaster/browning etc....
Would putting an sds adapter on a corded bosch 650w sds drill be OK or is the gear ratio too wrong and put the drill under too much strain?
Would I be better off taking a chance and buying a cheap mixer drill (sub £50) like silverline and using that?
I'm not a tradesman so will only be using for a bit of DIY when required.
Thoughts?
Jim
Thoughts?
Jim
