I have a construction - a simple plastic flat roof fixed on wooden pillars (roughly 12m x 3m) which performs the function of a simple parking space. I would like to put walls around it (leaving one long side open) to cover the place from wind and rain.
The question is - what is the cheapest reasonable way of building walls (roughly 2m high, 18m long) which could withstand rain and wind?
I thought about ordering some acrylic sheets and then painting them, but... they are surprisingly expensive (one website quotes £120 for 2mx2m sheet). Maybe I should buy plasterboard (what type?) and then paint it with some exterior/protective paint?
Or, I have found this plywood - http://www.builderdepot.co.uk/12mm-x-1220mm-x-2440mm-wbp-bb-cc-external-plywood.html - £17 per sheet seems reasonable... would that work?
Thank you all very much for your thoughts and help!
