D
Deleted member 242536
Hi All
So I have an old workmate which is like 20+ years old, kept in relatively decent nick aside from the loss of the rubber feet and clamping bits. Came across a few videos on Youtube of people building their own workbenches and replacing the tops of the workmates which inspired me to do something similar.
Obviously workmate tops tend to pretty small and mine is no exception, both boards measuring roughly 600mm x 120mm each and the thickness is around 15mm. So I'm thinking of replacing them with some 30mm MDF which would measure 800mm x 200mm. Use the old board to map the holes etc.
The question I have is, do I need to consider anything else before I go ahead with the above. Do I need to add any additional support to the frame itself if I'm increasing the size of the boards.
Thoughts opinions criticisms welcome.
