As we have TRVs on most rads, and the other rads are turned off permanently I am wondering about the most efficient (cheapest!) way of running the system. (There is no room stat).
My assumption on how it works is that the gas heats up the CH water to the temp set on the boiler dial, the pump sends it around the system, and the temp of the returning water is sensed. Once the temp of the return is hot enough the flame is extinguished. Is that correct?
Does the pump run continuously so that can keep being checked?
So does that mean that with most of the rads either off or TRVs set to low the water pretty much by-passes most of them and returns more quickly to the boiler, and therefore is more likely to return hotter, quicker?
So if I leave the CH on 24/7 then the cost involved is the continuous running of the pump, and the bursts of flame to keep the water at the temp set. I am wondering if that is cheaper than to to have it come on, say, every two hours and have to heat the water up from cold again every time?
Any thoughts appreciated.
