What medium do I use.
Need to build a wardrobe / unit not sure what its really called, need advice on materials. Max space available is w150cm h230cm d75cm(using perhaps d60cm)
Our old shop bought pine wardrobe was solid and over the years I have altered the interior to suit the needs at the time. I need to build a wider and taller wardrobe of a material that can be altered without leaving the room over the comming years.
Internal will be a w60cm section housing draws and shelves and a w90cm section for rails, what is the cheapest way to build this to a finished item. ensuring its strong durable.
My skill level I have made and fitted a kitchen, but funds are so tight now, it has to be a cheap.
Thanks in advance.
Thanks in advance.
