I have builders replacing the lead flashing on my roof. The property is mid terraced with a foot high block (above the tiles) between my property and both neighbours property and tiles running down. The old flashing was attached to this block (I think under the masonry) and went over the tiles. The builders have taken the old lead flashing off from the block and are putting new lead against this block and and refilling the masonry with sand cement. Is there any way I can check that they are doing the job competently? Thanks
