check valves
8 Mar 2003
Cornwall
kev, where exactly would you locate the check valves?
would you install check valves routinely on a shower installation or only on certain kinds of shower installations?
are there any other places in a plumbing system that you would install check valves?
MOD
split from hijacked post
check valves in the hot water pipe before the mixer (under the bath).
If you have an outside tap, should have a double check valve in the pipework.
Sometimes recommendations are given in the instructions that came with the mixer tap. Sometimes they are even given in your combi boiler manual.
