Would appreciate some guidance please.
I am fitting a thermostatic shower bar above a bath (Bristan Zing) I want to tee off the 22mm bath feed to 15mm for the shower, the old plumbing had check valves into the bath hot and cold not sure if they were double or single. Is it necessary to fit check valve for this set up and where should I fit them if necessary. I have a conventional boiler with an unvented heating system Mega Flow Heatrae Sadia.
Thanks in advance
Thanks in advance
