Check Water Light
6 Jun 2012
London
Can anyone help me please my check water light is lit on my Siemens dishwasher and will not go out? My model number is:SE25M851GB I have checked the outlet hose and even lift hose slightly of the ground level. Tilted the machine to see if water was still at the bottom but to no avail.
have you canceled the program and started a new one ..does it still stay on :?: if so pull machine out tilt the machine back and see if any water comes out and then try a program after you have done this once you have it back level on the floor.sometimes the impellor jug can go on these but try the tipping method first.
Thank you for your response I have tilted the machine to almost ground level and placed towels under but no water came out from the bottom.
First I would check for a fill problem.....No water supply, kinked hose, or faulty aquastop valve.
The E-number you quoted is missing 2 digits after "GB".
