I just had a Harvey water softener installed. They left a water hardness test kit which obviously indicates all is okay but the sceptic in me dug out an old TDS meter (Total Dissolved Solid) to check the water. I had the TDS meter from years ago when I had a special deionisation filter to create clean water for washing the car, I used the TDS meter to check the water was being filtered properly and I could visibly see a much lower reading. I thought the TDS meter would also indicate a similar reading from the softened water going through the Harvey system but I'm getting around 250 ppm from the unfiltered garden tap vs around 450 ppm from a filtered tap. I was expecting the value to be near zero but why has this gone up? Is the TDS meter the wrong tool to use for a home water softener? Or is my TDS meter possibly bust?
What's the best way to check the water hardness level to verify all is okay? I've seen water hardness testing strips, is that the better thing to use?
