Has any used used a chem vac soot remover stick to clean an oil boiler and are they any good. Now and again on a service call i came across the old ferroli oil boilers and if anyone is familiar with them they can be an nightmare to clean as they do not have any baffles, they have cast iron sections to restrict the flue pass and when you come across a sooted up one you could spend all day cleaning it, so as a easy solution i found out about theses sticks you just chuck into the combustion chamber and fire the boiler and it cleans the boiler. Has anyone tryed them?
