chemical metal plastic padding
27 Jan 2011
Middle Earth
I have been looking for this and it seems that it might no longer be available. Looking for the 2 tube set up like this. None of the main shopping sources sell it and from a quick google there are a few other shops that all seem to be out of stock.
I can find plastic padding super steel which comes in 2 equal sized tubes so just wondering if that stuff is a s good a the chemical metal version.
I also have JB weld which is good but takes a while to harden whereas the chem metal is really quick. Use it for anything and everything that needs to be fixed around the house and garden,
JB Weld SteelStik™ sets in 3-5 minutes and after 60 minutes, can be drilled, tapped, machined, ground, filed and painted. SteelStik™ cures to a dark grey color, is rated at a tensile strength of 4000 PSI and will withstand temperatures up to 300ºF
