I am having a problem that has been an issue for a good while with my car A/C.
My A/C start when i start my car after 2-3 second delay which is normal but go down as i move my car .it start again when car moving at around 40 kmph it start with a very faint click noise and i can feel the load of ac on my car otherwise works excellent when I am driving more than say 40 kmph. But at idle or moving in slow traffic. It's not putting out the cold air
I get it serviced from local mechanic who clean its parts and fill some gas (freon )but there is no change in this particular problem although cooling is better then previous when car running. I again visit my mechanic he checked it and enable to figure out problem and suggest plenty of reason i followed him and change my coolant clean radiator RPM checked fuse checked but no difference in problem.
Then i changed my machanic He checked pressure and all stuff and give conclusion that previous mech. did not fill gas properly and put a local gas in it and i will put original gas that is R-134a although he may be correct but i have a doubt if gas not original then why ac working fine on high speed
its looks like problem exist only at slow deriving I have no other issues under normal driving. My electric fans are both working.
So, here I am with my hat in hand asking for some help or advice
update : i istalled CNG kit i yrs back but problem look unrelated to CNG becouse i had this problem on petrol also
mt car model chevrolet spark oct 2008
