Chicken Coop lighting
11 Dec 2009
Liverpool
Hi, I have a chicken coop on an allotment. I want to put a PIR light up on the outside where the path is so I can see where I'm going when I visit at night. I've bought a 24V-230V inverter for use with a 24 V batterry. The plan was to put the battery and inverter in a chicken proof ventilated box inside the coop and run a cable to a 60W PIR light on the outside. What would I need in the circuit to meet regs. Do I need metal-clad fused switch? Do I need to earth the light circuit? Do I need an RCD?
With the setup you propose, the inverter would have to run constantly to make 230 Volts available to the PIR and lamp, otherwise it won't work. That would make for a very short battery life.
To eliminate the inefficiencies of converting your 24V DC to 230V AC, I would consider using automotive/boat/caravan components. In the absence of a purpose-made 24 Volt PIR lamp, you could probably use something like an alarm system PIR sensor operating a relay to switch the lighting.
I would consider using automotive LED lamps or 24 Volt fluorescent lamps for more efficient lighting than conventional tungsten lamps.
Never mind - this chap will be able to see perfectly well without it..
Anyway - flimbin:
1) Are you sure you're allowed to keep livestock on your allotment? From what I hear there are long waiting lists, and you don't want to give the council an excuse to kick you off. (And you'd be foolish to think that none of your fellow allotment-holders would ever complain)
2) Plan B:
You could always train the chickens to sh*t through a hole in the floor then use the dung to generate electricity...
My grandad's house backs onto an allotment site. He has one of them. For the first time in about 10 years all the plots are being used.
One of the plots is being used by a man who sells his flowers on markets. He has greenhouses galore - one time this was banned on these sites, to stop them looking like shantys. He had to get special permission from the council, but it shows they will allow it if a plot is being used.
