Hi all,
I was seriously contemplating taking down a chimney from loft downwards.
As space is a little tight in the dining room (doubles up as 2nd living room/guest room) I wanted to add TV to breast wall (sunk in) which would mean building a stud out of the existing breast. Doing this would obviously give me less room, hence removing the chimney breast.
Above is our bedroom and the breast there negates any option of adding a bedside cabinet (breast is snug against the bed...my side!).
We had someone look at the structural element and it was deemed necessary to add gallows brackets in the loft. The breast when it extends up into the bedroom and loft is only around 18", so not particularly large.
Given the amount of work I've also been tasked to do in the house and the space we'd actually gain, I decided it simply wasn't worth it (financially and the amount of extra dust...yet another skip or two). Besides, for the bedroom it dawned on me I could simply reverse the bedroom set up (when it's time to refurb) and face that breast and incorporate it into the furniture/wardrobes/stud for TV et al.
So down to two ideas - just after a little advice/experience.
1: As I want the TV 'sunk' into the wall (I'm doing this in another room, but building stud 'fireplace' from scratch) and conscious of that space (where the fireplace meets the dining table) I thought of part building a stud around the TV (32" size so not a biggy), creating a 'three tiered' effect....I'd combat any criticism by 'suggesting' it was 'Art Deco' to match the same style adoring the stairs
2: Place a lintel so far up then board in and around the new opening - either for AV gear, or 'ornamental' reasons. As you can see from the pic below, the fireplace is 'arched' and not in great nick. I was surprised how cheap it is to hire those Acrow strongboys for a few days. I'm fairly confident I could carry this work out myself too - just not entirely sure about lintel size - I've seen a few locally (concrete) for around a tenner, but won't commit to anything before making sure I have the correct size.
The lintel would be placed just above half way so the TV bracket can be placed in part of the new opening (will stud out to hold bracket).
I also really like the brick I've 'unsheathed'...not evident on that picture, but the bricks (house dated 1947) are a nice pale colour...possible I might incorporate that into the design (but that's another tale).
To sum up:
1: Plan will look a bit 'odd'
2: Reasonably easy to fit into lintel and work out lintel size?
Many thanks.
To sum up:
Many thanks.
