Just a couple of quick questions.
The chinmey breast had already been removed from the loft up.
So looking to remove down to ground level.
It's on the gable end.
Does removing a chimney breast (constructed internally) cause any weakness in the end wall?
And the other question is is it ok to cut the bricks that once tied the chimney to the inner wall leaf with a hammer and chisel or should they be cut with a grinder.
It's a lived in house so would like to avoid making any more first than is needed.
Cheers.
Cheers.
