Chimney breast render repair
9 Aug 2019
OP,
Remove all the render from the loft chimney breast - examine the raw brickwork for cracks or bulges.
And then, not necessary but if you have any doubts about the soundness of the brickwork pointing, you could observe while someone smoke tests the flue or flues.
Use the mortar for rendering the chimney breast - or mix your own at 3:1 sand & cement.
