I hope my first post makes sense and that someone will be able to help.
I am opening up a chimney breast to take a range cooker and would like to know what size steel to put in.
It will be resting on the breast sides with a span of 1700mm.
It will be at ceiling height supporting the end of two ceiling joists and the upstairs hearth stones.
I also need to bridge a two metre wide section with an RSJ this will be from the top of a supporting wall to an external wall.
There will be no brickwork above as it will be directly below the ceiling joists.
Could you please recommend the correct size and weight of RSJ.
Cheers Kev.
Cheers Kev.
