There is loads of information on the web about best practice for lead DPCs for single flue chimneys, and it all makes sense. However, I have a two flue chimney build into the inside cavity wall with the second flue closer to the ridge line, together with an upstairs room through which the chimney passes; and damp in this room is a significant problem which I have to fix.
I have spoken to various builders and they seem to have different views as to how the job should be done, which concerns me greatly as there should be a single view. As I understand it there should be a high level lead DPC (that's easy to understand) but also a low level lead DPC which prevents any damp in the remaining exposed part of the chimney penetrating the room space. But how is this implemented? A flat tray at apron level outside would end up part way down the wall on the inside of the house which would leave the wall very damp. Equally a flat tray at back gutter level outside would leave a lot of chimney exposed allowing damp to continue to penetrate. Should the tray be stepped in some way by hand crafting it on site? I can't afford to experiment with solutions to this problem and hope that there is a proper solution that builders can implement.
This photo shows my chimney.
View media item 70275
Any advice much appreciated.
