Hi
am having problems with fumes from my oil aga, I believe that there is no flue pipe to the cowl( fitted several years ago!)and there is no acess point on the cast iron pipe from the Aga, it has been run into an old chimney and sealed with a steel plate so there is no access from the bottom hence, I am told that the previous owners had to take out the the external stonework 2/3 up the chimney to gain access to clear a birds nest
Whilst until now it has been probelm free for 10 years, to solve this now and for easy future service can I change the flue to come out of the side of the chimney wall rather the top -there are no windows above or can you suggest another solution
thanks in advance
thanks in advance
