Hello,
Forgive this rambling question, I seem to need to give so much info to avoid confusion.
Last year I had a chimney and liner fitted for my new wood stove.
The liner is held in by a cowl that straps to the chimney pot and to the top of the liner.
I began to noticed a slight knocking that occurred during windy weather, that has over the last year become louder and louder and more frequent; to the point where my neighbour commented and to the point where during the last bout of weather it became ridiculously frequent and chaotic.
I am not sleeping well.
It is heard most loudly in the wall in the bedroom but can be heard from downstairs also.
If I put my ear to the liner I can hear it but not to the extent that I would imagine if it was the actual liner moving.
It is a thumping with some weight behind it.
Imagine dropping a tennis ball from exactly three inches high onto a concrete floor. Dum,dum,....dum,.......... dum.
I don't know if it is it more likely to be the liner or the chimney or anything else that anyone has experienced.
Has anyone on on this site experienced chimney liner thump; I have searched and cannot find any information on it, it seems so inflexible and heavy that I can't imagine it.
I removed the stove and pulled the liner down as much as I could , gaining only about 2", is it possible that it could be knocking insde, even when it is this taught? It made no difference.
Is it possible for a chimney itself to rock with the noise that I have described ? I would think that something that heavy would rock very slowly ?
The background to all this is; the winter before we could hear knocking during extremely windy weather but to nothing like the extent of the present.
The builder said the chimneys up there were a bit dodgy and could do with repointing.
The original chimneys were in a grouping of 8 but after renovating, only the outer 6 were replaced. The builder had to reopen the inner flue for my front room and put on a chimney pot .
Could this have helped weaken the chimneys?
I have stared for hours at my chimneys through binoculars and cannot see any movement. I can see cracks in the outer chimney flaunching though.
Another chimney on this street needed chimney work recently, although this was an end terrace, ( 3 storey, not 2, like mine ).
Well, if you got to this point, well done.
Any advice?
Thank you for your time.
Henry.
Extra facts:
It is proper double walled stainless steel liner.
The liner is not insulated; we read that it was not necessary in this instance.
Any advice?
Henry.
Extra facts:
