Not sure if this question belongs here or under roofing but I'm thinking of getting the top of my chimney pots capped and was wondering if there are any particular types I need to get as I have a gas fire in the lounge. The gas fire is the type that uses Radiants - but I may change this sometime in the future to an inset fire.
Do I need a certain type of cap for the chimney pot or will any that has ventilation holes be OK. I'm concerned that having the wrong type of cap could lead to carbon monoxide problems.
I have seen these:
http://www.travisperkins.co.uk/Hepworth-Chimney-Pot-Fluevent-Red-180mm/p/861625
http://www.travisperkins.co.uk/Hepworth-Chimney-Pot-Bonnet-Insert-Red-180mm/p/861629
http://www.travisperkins.co.uk/M-A-D-Junior-Cowl-Terracotta-Strap-Fix-310mm/p/954172
will any of these be OK? Which type would be better or are there others I should be looking at?
I have seen these:
