M
MattLowe
We're thinking of removing the rear chimney breast at ground and 1st floor of a 1930's end of terrace house. Two chimneys, one in the front room, one in the back rising to merge in the loft.
Unfortunately the neighbour has already removed his chimney in the back room, ground and first floor, supported with timbers in the loft (which can't be legit!).
My questions:
1: Is it still possible to remove the rear chimney breast in our property?
2: Would it be expensive?
3: Where can I get an indication of the detail required? I've found plenty of details on gallows bracket but expect it will involve more than this because the neighbours chimney breast is already removed. Don't worry I'm not planning to build to it, just need an indication (or number of a friendly structural engineer in Merton.
4: Worst case would be to bring the whole chimney down and make good the roof (neighbours willingness required). Is this possible? I haven't seen any other houses where this has been done.
Many thanks in advance...
My questions:
