I have lived at the same address for over 20 years & I had intended to replace my inset gas fire with a newer High Efficiency model. This would be the 3rd new gas fire in my time here. However the Gas Safe guy says I need a chimney pot for emissions. Currently the chimney stack has a concrete slab on top but there are gaps (house brick size) on the four sides of the stack immediately below the slab. I have had absolutely no problem in the past & the burnt gas emissions is evacuating through the ready made gaps into the sky. Surely this is perfectly acceptable. I can't find any advice which states I must have a chimney pot to evacuate the burnt gas emissions.?
