The Chinese, as we all should know, brag wildly about their rechargeable battery's aH capacity. They also brag about lamp output watts.
I put the Christmas tree up 10 days ago, then not long afterwards, its 12v 16w MR11 GU11 QH lamp blew. I managed to borrow a 10w version, left over from converting the caravan to LED a while ago, it worked, though a bit under bright.
Ordered a 5w 10v to 30v MR11 GU11 ac/dc LED spot, which should have been a bit brighter than the 16w original, in fact it was much dimmer than the 10w, so I emailed the seller - not cheap these lamps. Seller replied to my complaint suggesting it was nearer 0.5w than 5w LED, with a request for the usual photo of the problem - what, or perhaps watt?
My usual reply to that silly request is - I do not possess a digital camera, despite having several.
Out of curiosity, I have just carried out a few tests of the lamp on my work bench...
At 12v it draws 0.070amp = 0.84w
At 20v it draws 0.042amp =0.85w
At 30v it draws 0.072amp =0.86w
Far below the 5watt lamp it was sold as. No doubt the seller will send me a replacement, which will be identical and I will reject that too and eventually demand a full refund.
Were it not for the fact that the 2w LED's are dc, which I replaced the 10w QH lamps with and which I found were much brighter than the 10w jobs - I would borrow one of those.
