About 10 years ago I floated chipboard T&G over 50mm polystyrene in my garage. I believe that the chipboard was waterproofed flooring grade.
Unbeknown to me the felt under the corner of the roof tiling has failed letting water run down the inside of the garage and under the chipboard floor. This only came to light when I noticed a black mould patch appearing on the plasterboard ceiling in the corner.
Roof leak has now been fixed but is there anyway to dry out the flooring that doesn't entail stripping back the whole floor and replacing?
I've taken the vinyl tiles off the top and have got a large fan blowing across it and it has started to recede but is there anything else I can do?
The chipboard appears fairly strong at the moment but I don't want it to go soft and start disintegrating as the garage is home to two cars.
Is there any rot solutions that could be applied which would combine with the water and at the same time curing to make a strong structure?
Richard
Richard
