Fed up of the creaking upstairs chipboard floors in bedrooms and landing. I am looking for a long term solution prior to new carpets
Some years ago I fixed the same problem in one bedroom by putting spax floorboard screws in (a lot!), close by the original nail. Only problem was that I managed to screw through a heating pipe on the last but one screw!! (I had checked with detector prior - but...) and had to call out emergency plumbing.
Thinking now that it may be the best solution to try and remove and replace the ring shank nails with screws (and maybe PVA glue down joints). Problem is removing ring shank nails in the past proved to be a real PITA - only way at the time was to chisel a surrounding hole and pry the nails out!
Is there any tool or particular method that will help as I am looking at several hundred nails?
