chipped vanity unit
23 Sep 2013
Glamorgan
Any ideas on the following.
Fitted a back to Wall toilet vanity unit with concealed cistern but when drilling for flush push button the poxy laminate unit chipped. . Its the standard high gloss panels so tried mastic mastic but it stands out like a saw thumb. can these units be repaired or have you any ideas to help me out of a hole? The chip is on the line of the push button so if the button was a touch larger you wouldn't even see it[/b]
new syphone woth bigger push button, I know the Girbert ones a MASSIVE!!! 2" I think.
Also isnt the section you drill the flush button into a small removable panel (usualy are) Can you not ask the manufacture for another
Also see if you can source some kind of washer (chrome or a complimentary colour) to enlarge your push button.
Also kitchen firms will make matching panels in gloss wood laminates cut to size and edged (wont be cheap though)
Personally I would try to source a chrome bezel to fit around the button. Or you might be able to get a replacement panel from the supplier.
Just beat me to it.
Thought of the washer idea but can't find one on the Web. replacement panel looks only option but bloody expensive chip!!
