My old Bosch has given up the ghost and so im looking to replace it.
Although it was a 'Green' Bosch it served well with great power it was a PSB 14.4v V-i
Anyway ive seen 2 drills that i like but cant quite decide which i should get.
It wont be used all the time but when i do i need some power.
Now ive seen a Dewalt drill for £80 with better spec and a lower price BUT its only got 2 x 1.3Ah Ni-Cd Batteries
Heres is the spec:-
Voltage 18 V
Battery Capacity NiCd 1.3 Ah
Chuck Capacity 1.5-13 mm
Power Output 400 Watts
No Load Speed 0-500 / 0-1700 rpm
Beats per Minute 0-8500/ 0-29000 bpm
Couple maximal 44 Nm
Now the 2nd one is a Bosch(blue) for more then double the price £180 BUT it has 2x3.0AH Li-Ion batteries.
heres the spec
Torque, max. 45 Nm
Torque, max. 19 Nm
No-load speed (1st gear / 2nd gear) 0 – 400 / 1.400 rpm
Max. impact rate 21.000 rpm
Battery voltage 18 V
Torque settings 15+1
Now i know the batteries will be a big factor but if you take those outa the equation the cheaper Dewalt has a better Impact Rate and Load Speed.
so is the extra money going on batteries alone with a slightly lower spec drill or am i reading this all wrong?
many thanks
Heres is the spec:-
Voltage 18 V
heres the spec
Torque, max. 45 Nm
Torque, max. 19 Nm
many thanks
