Chome Trap waste connection to 32mm pushfit
24 May 2006
Southampton
Hello all.
I have a problem connecting my chrome trap waste pipe to existing pipework, i was hoping it would fit into 32mm pushfit, but it appears to tight, i have managed to get it really almost in, but wont slot right the way through, problem is i have now tiles around this area so access is difficult :( I though i tried it and it fitted but this turned out to be the connection to the click - clack waste that fitted, the other chrome pipe is slightly wider.
Any help greatly appreciated.
The chrome pipe is usually slightly a diff diameter to plastic so you will have to use a compression fitting. Mc alpine universal connectors should do the job.
Pete
