I am finally going to install a shower cubicle. I have a number of questions however, the primary question is which type of shower?
Any quotes to do the work in Swindon appreciated! I supply the shower, base and enclosure.
Ideally I would like to fit an integral pump power shower. I ran one over the bath for a number of years without any real bother so therefore, I hope I can repeat this in the shower enclosure.
I have a dedicated cold feed from the header tank in the loft. The hot water will have to come off the hot water circuit currently in the bathroom. The hot water is cylinder fed which has the header tank in the loft (with the cold feed alreday mentioned above).
Can I get away with a power shower? I do not want the complication of an electric shower and I cannot take a feed off the hot water cylinder - too far and too awkward.
Next question.
What should I use to put on the walls for before tiling? The walls themselves are not suitable to tile onto due to old plaster. I also need to build a small amount of stud wall as one of the walls is only 45cm wide.
Thanks for your help
Bob J
Next question.
Bob J
