Hi all
I have a large house that used to have very poor circulation to the furthest rads in the system. A plumber installed a much larger pump and told me that would sort out the problem.
It didn't.
I eventually had lots of floorboards up and found out that the whole system was using 15mm pipe - It left the pump and was fed with 22mm pipe downstairs to a sort of home made distributor but before it reached this it went down to 15mm which seemed crazy to me.
I sorted this out myself and then replaced as much of the 15mm pipe with 22mm as I could.
This did work !
Now I am changing over to a ASHP with low water temperatures that will be running 24/7. The pump seems to use a lot of power even though I have it on the lowest setting so Having it on 24/7 will cost a lot in electricity.
Hence me asking this question.
My present pump is a grundfoss 3 speed type UPS 25-80 185.
I would like to replace it with an A rated low energy pump.
How do I work out what size of pump I need?
is it number of rads or total size of rads ? something like that?
Oh and do you recomend the Grundfoss Alpha 2 ?
thanks in advance
Mike
It didn't.
This did work !
thanks in advance
Mike
