Now that nearly all boilers can modulate their output over a wide range, is there any good reason not to go for a larger output model (within reason) in order to get better a better hot water flow rate?
I am planning on replacing my old Ideal Mexico Slimline heat only boiler with a combi in the next couple of months. I am looking at the Intergas Eco RF range, but am not sure which size would be best.
The 30 model is rated between 7.2 and 23.7KW for CH and can supply 10.5l/min of HW whereas the 36 model is rated between 7.6 and 27KW for CH and 13l/min for HW.
I have no experience of combi boilers but would like enough HW flow to guarantee a similar standard of shower to what I get now - the current system is pumped and very good though the pump is very noisy.
The property is a large 2 bed flat over 2 floors with 8 radiators, property is 1990 ish so insulated but not to modern standards and is located in chilly scotland! Currently there are two showers both pumped that deliver about 14 l/min flow, it is unlikely that both showers would be used simultaneously. Not measured the mains water pressure but seems fine, I get about 20 l/min flow of cold water from the kitchen tap.
So would the 30 model be adequate for a good shower, or should I go for the 36 model? Is there any downside to having the larger boiler for heating - it appear to modulate down almost as low as the smaller model.
