When I had a bathroom refurbished 5 years ago by Dolphin Bathrooms they replaced my old 100mm fan, which runs by ducting to the roof, with a Silavent PVS 100TBS axial fan (p.15/16 of the document at: www.silavent.co.uk/pdfs/section_02.pdf ) which worked reasonably well and wasn't too noisy.
• Extract Volume : 85 m3/h
• Sound Volume* : 29.0dB (A)@3m
• Voltage : 230-240v AC~
• Frequency : 50 Hz
• Wattage : 11W
• 155mm x 165mm
• Max Pressure : 33 pa
The fan has now stopped working (although the automated shutters still open/close in accordance with the timer settings). I’d like to get it replaced by something similar but Silavent no longer make this model or seem to be able to suggest an alternative to fit the same size recess and suitable for use with ducting.
I don’t know enough about fan performance to recognise what would be suitable for my needs. I've looked at the Vent Axia VA100XT Axial fan (eg. www.diynot.com/shop/Ventaxia_Va100XT_Fan/18859 ) as a possible replacement.
• Extraction Rate 90m³/hr
• Noise Level 31dBA at 3m
• Auto Shutter
• Width: 155mm
• Profile Depth: 44mm
• Timer: Max. 25min
Could someone advise if this or maybe another fan would be ok for a straight swap please?
• Frequency : 50 Hz
• Wattage : 11W
• 155mm x 165mm
• Auto Shutter
• Width: 155mm
• Timer: Max. 25min
