Guys - am in need for some experienced advice on this one.....
Before the plasterers got busy in my bathrrom I chisellend into the wall and fitted the pipes and valves for a new towel rail.
I measured it up perfectly and secured the valves in the right position.
Bewtween that and the plastering being done the plasteres must have knocked it off positon.
I now have two valves that miss the towel rail connection by a cm each.
Problem - there is only 2-3 cm of copper pipe exposed to play with - can anyone recommend an effective way of bending these pipes slightly so it all lines up? To bedn them will be trick as the valve connect to the pipe via a chrome compression fitting.....
FYI - the 2-3 cm pipe coming out of the wall is fxed via a compression elbow in the wall under the plaster.
