Chuck for Bosch PSB 24 VE-2 24V
15 Nov 2010
Glasgow
Hey,
I have a bosch drill that I was given 4 / 5 years ago thats used for general DIY work around the house. Buying an 1940s ex council house two years back its seen some heavy use over the last year or so and the chuck has started to fail.
When you use it on hammer the chuck will refuse to release the bit sometimes - it takes brute force and wiggling to get the bit out. Its getting worse.
I'm fairly happy its just the chuck - the drill works fine and the clutch etc seem ok.
Usually if it was a work tool I would hand it back in and go "fix it" but as its my own tool I thought it would just be a case of buying a replacement chuck... however there seems to be a lot of chat on the web about proper hammer chucks etc and I have no idea what to buy!
So....
I'm looking for a recommendation for a new chuck. Anyone have any tips?
Cheers,
David.
Having a quick google, you might get one to fit for £15-£20. The prices for the correct one seemed to be upwards of £35.
As the drill is no longer made, albeit working fine, for them prices i'd be buying a new one.
Thats near to what I found, the drill was a present from my wife however and has been a trusty tool for so long I don't think I could just replace it...
OK
Plan B
Cheap non percussion chuck, £6 from toolstation. Keeps her happy.
Then treat yourself to a new percussion drill - doesn't have to be ott price wise.
She's happy you still got and use here drill - for lightweight occasional use.
Your happy because you've got a drill suitable for your actual needs.
you have off course cleaned the chuck out and oiled it ??
I cant actually get the chuck out anyway - I think the clutch or gearing might be slipping actually.
With the grub screw removed the actual chuck wont unscrew, it just clicks like the clutch.
Checked some youtube videos that didnt really help either - put the drill away before I resorted to brute force and damaged it worse.
Any tips on how to remove the chuck?
Thanks! David.
