Good morning all
My wife and I returned home after a couple of days away to find the CH running continuously. The boiler is a c. 25 year old Glow Worm 65-80 which is situated in an outhouse with the circulation pump upstairs in the airing cupboard.
I searched the forum and noted common problems appeared to be the programmer or a frost stat. I removed the programmer (Landis and Gyr) and reconnected the electricity and the boiler immediately started, despite the room thermostat being turned right down. As it was late I disconnected the electricity again, turned the boiler thermostat right down and went to bed.
This morning as soon as I connected the electricity again I heard the cirulation pump start up immediately, however the boiler didn't start until I manually switched it on. I thought it might be something to do with the programmer but no matter what I do with the programmer controls the pump keeps going. Turning the boiler thermostat off has no effect either. Is this consistent with a frost stat problem - even though the temperature outside is around 5 degrees this morning?
Any advice would be most appreciated.
Alan
Alan
