Here's an odd one...
A year or so a room which has its own ring final on a 32A RCBO, tripped out due to a live-earth fault on a damaged extension lead.
After resetting the RCBO the computer in the room would not power on, and the HDMI input on the TV it was plugged into stopped working (TV worked fine apart from that). The PC was replaced and plugged into another HDMI input.
Recently the room had a faulty appliance which again tripped the RCBO (I would guess another live to earth), and after resetting the PC (new but same model as the previous one) would not power on and other HDMI input on the TV will now not work.
The PC has been replaced again, and as there no working HDMI inputs left has been connected to the VGA input.
There must be some underlaying issue here, I really don't know but could the RCBO be tripping out slightly too slowly allowing voltage to travel into the IT equipment through the CPC and cause this (rather specific damage)?
