Yes you are probable correct but I don't want to make a big mistake! The main reason I am asking is that I have a table saw which uses a 254 blade with the sae kerf. I have very nice blades for the table saw and think it would be good to be able to interchange if required
but don't want to miss the obvious! I thought that there nay be someone on here who has the knowledge. I am sure there is enough clearance to make all the cuts with the 254 blade but I question why the manufacturer has stipulated a 250mm blade my thoughts were motor power when cutting very heavy timbers it can cope with 75x430mm. It might not seem much but if you were cutting a roof timber that size maybe the motor would go west with a 254mm but with a 250mm it might be ok? I can't see how 4mm could be such a difference but the makers must know why!
