the kerf[thickness] bore[centre hole] and diameter must be the same
the bore off the blade can be bigger with a reduction shim/washer but not nessiserily an easy task
Hi john, Bike is probaly in garage but hard to to be exact as stolen around 4 years ago, now switched to pedal power. Thanks for info, brought saw few years ago and not used a lot. Have ripping blade on and need blade for cutting plastic roofing material, Have performancepower saw from B&Q.
