circular saw blades
8 Apr 2006
I'm looking at replacing my circular saw blade, as I want to do some fine woodwork and my current blade is only for ripping.
What should I be looking for in a blade to ensure a finer cut with no splintering?
My current blade is 254mm. Can I fit a blade that is smaller/larger than this (I've seen 250 and 255 sizes available)
heeelllooo jeffke and welcome :LOL: :LOL: :LOL:
freud pro 60 tooth slow progress when ripping but the finnish can be so smooth a light sanding can give you a finnished surface
254 is 10" 255 will fit as will 250 as your + 0.5mm or -2mm so should be ok
the bore is the most important measurement
http://www.toolstation.com/search.html?searchstr=37497
or 40 tooth quicker ripping less smooth finnish
http://www.toolstation.com/search.html?searchstr=74883
these are also thinnish kerf blades about 2.7 youll need to check this is compatable with your wriving knife
Such a small difference won't be a problem, although you may need to adjust your riving knife to be slightly closer to the blade if you go to a smaller blade.
I'd try to pick a blade with the same kerf and body thickness as your original rip blade that way it will work with your riving knife. The kerf (width of the teeth) may well be something like 3.2mm on a 2.8mm body requiring something like a 3.0 mm thick riving knife.
If you want to rip and crosscut go for a combination sawblade - probably around 40 to 48 teeth in 250mm. These are a compromise and don't really have the same qualities as either a purpose made rip or crosscut blade, but they are a reasonable all round blade to have on the saw at all times. For fine crosscutting theblade's tooth count will go up to 60 or more teeth, but ripping performance will be cr*p. For sawing MFC (melamine faced chipboard) or veneeref MDF, etc you'll need something different like an ATB (alternative top bevel) blade probably with with 54 to 66 teeth.
Scrit
Scrit said:
I vote for big-all to be in charge of the welcome wagon!
Scrit
the trouble is is remembering if someone on say 5 posts has already been assaulted
or not noticing its a new poster and forgeting to greet them giving them an inferioraty complex :D :D :D :D ;)
