circular saw, corded or cordless? help please
4 Sep 2010
Durham
hi, i want to buy a circ saw for cutting manufactured board and just general diy jobs,
i was going to buy a makita cordless but a few people have advised against it because of power or run time, i have no specific reason to needing a cordless, just could use my drill batterys with it.
what do you think i should?
any help would be appreciated :)
thanks
tom
A corded circ certainly will have more power than any cordless. Depends what cordless drills you have and whether the manufacturer does a circular saw that uses the same batteries. ;) ;) ;)
thanks for a quick reply, ive got makita batterys, and could get a saw to go with them but apparently my 1.3ah batterys would be naf
do you think i will be ok with a cordless or should get a corded?
thanks
tom
As you would need to invest in extra batteries to make it usable then the cordless option becomes a lot more expensive than a £60 bosch b&q corded jobbie (or similar)
I would have said different if you'd had say 3.0ah batteries.
If you will be cutting full length 2.4m boards then something like this will be useful.
Try searching on YouTube for "cordless circular saw" as I remember seeing some videos about them. Might help you make your choice.
Rgds
all depends on what you are thinking off doing
if you are doing a 8ft and a 4ft cut every hour and using the drill in between then no probs
if you plan 8 x8ft cuts then no unless you have time to spare whilst you wait for batteries to charge
basicly what you have is the higher draw tools with the lowest power batteries
a bit like having a bus with a car fuel tank it will work if the bus is on short journeys with long breakes inbetween to refuel
another point you need to be sure the batteries and saw are compatable as in
if its not ryobi or dewalt new batteries dont fit old tools or old batteries dont fit new tools
so assuming your batteries are nicad your saw needs to be nicad as well
If you dont need cordless then go for corded.
I have a Ryobi drill with 2.4Ah li-on batteries and I bought the angle grinder with the set as it was on special offer at half price. I tried using it to cut up a 19" rack and each battery lasted about 3 minutes.
Your batteries will probably be ok for a quick couple of cuts but if you want to use it to cut more than a few things at once then you really want to go for a corded model.
hi everyone thanks for replying,
i think im going to go corded, i will also be using it at work so i will be using it sometimes for days at a time, but im on a bench so i will be ok with 240 i think,
any recomendations for a corded circular saw? preferably with laser?
thanks tom
p.s. i loved big all's comparison :LOL:
as long as you remember with li-ion batteries you can get a 70 percent charge in about 15 mins it can help extend the work time
some people get confused and think higher amp hour batteries means greater power
so i normally say the engine is the volts and the fuel tank is the ah but in this instance to exaggerate and make the point how undersized it is i went for something bigger :D :D
this is better
nice saw, bit pricey though :), any recomendations
preferably under the 80 quid mark?
thanks
