We have a Gundfos circulating heat pump on our central heating system which won't turn off unless we switch its electricity supply off- so when the heating is off, the pump is still operating. Could this be due to air in the pump?
Nothing to do with air in the pump.We have a Gundfos circulating heat pump on our central heating system which won't turn off unless we switch its electricity supply off- so when the heating is off, the pump is still operating. Could this be due to air in the pump?
Is this a new problem - the pump used to turn off ok - or has it always been like it?
When you say "switch its electricity supply off", do you mean that the pump is connected to a wall socket with a switch, or do you mean turn off the electricity to the complete CH system?
Which boiler do you have - make and model?
But that would normally keep the boiler running as well. Probability is that the boiler has an overrun for the pump and this is faulty. That's why we need to know which boiler it is.Could be the contacts/switch in the motorised zone or 3-way valve failed closed which keeps the pump running.
matt1e";p="1088601 said:yes I agree probably a faulty overrun unless its a gravity HW system
more info really req boss
Thanks for all this- will get all details to you after Christmas- have a good one!
bossbabe";p="1088622 said:matt1e";p="1088601 said:yes I agree probably a faulty overrun unless its a gravity HW system
Thanks for all this- will get all details to you after Christmas- have a good one![/quote
The boiler is a Baxi Solo 2 50 PF- does this help?
Not at house now until after Christmas so don't know make and model of boiler- sorry. Its a gas fired one and was installed in 1997. Could it be a boiler needs a service as we haven't had that done since we moved there a year or so ago- previous owners said they'd had regular services.
