CH system problem – part system heats okay – one section has no return flow.
Boiler – Potterton Suprima 80L
Pump – Grundfos UPE 15-60 [set on proportional pressure
HW - Fully Pumped and always okay
CH - Flow/Return T’s off at a point where:-
Section one – 22mm pipes run down feeding top floor Lounge/Office mid floor Kitchen and part lower floor Bathroom/Bedroom and are all heat okay.
Section two – 15mm continues its run for another 5mtrs then drops down, first feeding mid floor closet, hallway lower floor two bedrooms and bathrooms the furthest point being over 33mtrs away
At the point where theT’off is the flow pipes continue to be hot as far as I can feel before they turn down but the return is cold from the T’off as far as I can feel.
I have as far as I can tell expelled the air and continued for some time allowing individual rads to get hot, but the flow is still stone cold at the T’section.
It has worked before at the furthest point but not for some time now.
My thoughts are:
- the tube is undersized or
- there is still air somewhere which effectively cuts back the power of the proportional pump speed
Would a solution be to add another pump in series and wire in parallel so that it gives section 2 more power to circulate and come on at the same time as the initial pump, if indeed it is a circulation problem.
Any ideas??
My thoughts are:
Any ideas??
