circulation pump??
19 Sep 2008
hi,
here's what's going on:
boiler in the attic, make: ACV Delta gas boiler, water is at 70 degrees Celcius, pressure is ok, everything seems fine,
circulation pump: Grundfos ups 25 40
house thermostat, but connections are bridged to make shure it's on
Problem:
there's no circulation to the radiators in the house. I can't seem to get power to the grundfos for some reason, zero measurement at the terminals of the pump.. (i unscrewed the thing and it's not stuck or anything). Is there possibly another power-interruptor somewhere in the system that i'm overlooking????
any thoughts would be sooo appreciated.
best,
patrick
i did, that's how i got to write "zero measurement at the terminals of the pump". : )
but, i found it!
so for the other people after me:
the boiler has two temperature knobs, one with a bath icon, and one with a radiator icon. apparently they can not be used at the same time, when they are both set to high temperatures the power to the circulation pump is interrupted.
As I turned the bath temperature knob down, i heard a click, et voila, 230 volts at the pump, heat in my radiator. happy happy.
