Hi
We recently had to turn off the water, as my husband wanted to do something with the radiators, in any event, we turned off a stopcock and a gate valve, upstairs. These pipes look to lead directly to the water tank in the loft.
Since then the water has continued to flow (presumably from the water stock in the tank), we have since turned the stopcock and gate valve back to how they were (although can't easily tell which way they should turn), however we now have cold water in the upstairs taps and kitchen (pressure fine), but neither cisterns will refill and the downstairs toilet cold tap produces no cold water, in addition to the the pressure on the boiler has reduced to 0.
I have been reading and it seem the pressure issue with the boiler can be solved by refilling using the pressure valve, but I'm not sure how to solve the cold water problem, has anyone any advice?
Thanks in advance for any help given.
