Hi folks. Hope you can help.
I recently bought a new toilet pan and cistern online. It came with a blue and white fill valve, the compact type, not a ball cock like in my old cistern. The new cistern isn't big enough for a ball cock type.
The problem is that the fill valve is almost totally restricting the refill and the cistern is taking about 30 mins to fill! I removed the flow restricter so it's not that.
I went to Plumbworld and spoke to 2 plumbers who were in buying stuff. They recommended trying a Fluidmaster fill valve so I tried one of these and the issue is the same if not worse, virtually no flow. When I take the top cap off the valve there is a good flow but as soon as I replace the top cap it stops again.
My supply is low-ish pressre from a tank but not very low and the Fluidmaster fill valve states that it is suitable for low pressure systems.
I had no problems with my old ball cock system so surely tbe pressure can't be that bad?
Any ideas???
Any ideas???
