Cistern inlet valve float type
28 Nov 2010
Edinburgh
In my flat both my circa year 2000 close coupled armitage shanks float type inlet valves have become problematic at the same time- both noisy when filling. One like this for months, the other suddenly very noisy (which in some ways is quite good because I was just about to fix the original noisy one!)
Both toilets are shanks from same era but both cisterns have different guts-
One has a "Derwent Macdee" (orangy/red float+blue top syphon)
The other a "Freeflo" (blue float+green top syphon)
What's my best route to fix this? Any advice on what to ask for/how best to repair? The derwent macdee one is scaly and 'orrible everywhere, the other all clean and nice. So, maybe complete renewal of it's inlet system? Don't really want to go near the syphons if I can help it- they seem ok.
Advice much appreciated. Thanks
Its probably best to renew both valves.....check out the Fluidmaster Professional one, with the brass threaded end.
John :)
Yep, thats the one - an excellent piece of kit and all you'll need after that is a new fibre washer (1/2") for the pipe connection.
John :)
I see these are a replacement doing away with float etc.
Will there likely be enough room for it, the fill hole in both my cisterns are fairly close to the corner?
The float actually rises up the stem of the valve.
Whether it will fit your particular cistern I can't say.....maybe the slimmest one is by Torbeck (another good make) but the type you presently have is certainly available.
The likes of B&Q etc have a few choices.
John :)
Many thanks John
When I first glanced at the picture of it I didn't notice the float was offset to one side, so I imagine it should be ok. Most cistern inlets are pretty near the corner of the porcelain I imagine...
Scott
