- Joined
- 4 Nov 2012
- Messages
- 4
- Reaction score
- 0
- Country
Hi
In the last few days I've noticed that my cistern is not filling up as quickly as always. It can take 1 hour+ to fill. There is only a trickle of water coming in.
I have attached pictures of the type of cistern/part, it is.
//www.diynot.com/network/TroubledCistern1/albums/
Would anyone have an idea why it is so slow to fill all of a sudden?
I've poked around with the plastic sleeve/tube at the inlet, behind the float, but this was not the solution!
There doesn't seem to be that much pressure (although it is hard top tell), but the other toilet is filling fine (on same floor). And the components in the faulty loo don't seem to be visibly damaged or different to the working loo.
I'm not sure so if it is a pressure problem or if there is something wrong with the plastic see through perforated tube. In fact, very little water is coming out of this, it is mainly just dribbling down the side of the white inlet tube connected to it.
I would be very grateful if somebody could offer some suggestions.
Dave
Dave
