cistern query
dk3
13 Jul 2006
Hi. i have a chain flush cistern, water keeps running in to the bowl even though the tank seems to have filled up, I have checked the flush goes back fully, is it a problem inside the cistern, thanks for any help
Chain as in small one inside cistern connected to flap valve @ the bottom :?: as opposed to chain hanging from iron/black rubber cistern 6 foot off the ground ;) .....it`ll be the flap valve not seating properly.....ok you checked that.......maybe the seal round the valve to the cistern base :idea:
thank for reply, its 6ft off the ground cistern, is the seal round the valve to the cistern base inside or out of the cistern, sorry I need this in idiot terminology
A high level one :eek: ......anyways ........put a new syphon in ;) I`ve come across one that had a split in the syphon letting water through. It`s not going to be a flush valve on a high level, I`m pretty sure of that
